1995 Chevy Celebrity engine
39,000 MILES • 4 CYL • 2WD • AUTOMATIC
TERNOVA53
the car works wonderfully in town, however...when I get a certain ways out of town and come to a stop sign and apply the brakes the car kills. it starts right up again but then it chugs and sputters for awhile until it is again running fine. then of course there comes another stop sign 10 miles later and it does it again. I had a mechanic look at it (this was after I persumed there was water in the line and added a can of heat) he didn't know what it was even though it did the same thing to him. he suggested I use Lucas oil trans. treatment. that hasn't helped either. my car has 39,000 original miles and it's a 1995. help please!!!!!!!!!!!!!!!!!!
Jan 3, 2008 at 12:02 PM
BMRFIXIT
  • 19,053 POSTS
[quote:92e277d96d="ternova53"]Other Category problem
1995 Chevy Celebrity 4 cyl Two Wheel Drive Automatic 39,000 miles
the car works wonderfully in town, however...when I get a certain ways out of town and come to a stop sign and apply the brakes the car kills. it starts right up again but then it chugs and sputters for awhile until it is again running fine. then of course there comes another stop sign 10 miles later and it does it again. I had a mechanic look at it (this was after I persumed there was water in the line and added a can of heat) he didn't know what it was even though it did the same thing to him. he suggested I use Lucas oil trans. treatment. that hasn't helped either. my car has 39,000 original miles and it's a 1995. help please!!!!!!!!!!!!!!!!!![/quote:92e277d96d]
let them check tranny
and lock up torque converter solenoid
it happen when you drive at speed around or over 44 miles /hr
if so converter solenoid need to be replaced
they can disconnect it for you and try to do your trip and check it this way
good luck
Jan 3, 2008 at 12:20 PM
