1990 Chevy Celebrity engine dies and stalls
120,000 MILES • 6 CYL • FWD • AUTOMATIC
FREDDY27
  • 5 POSTS
i have a 90 celebrity with 3.1 car only gas 120000 miles has always ran like a new car! left my house got a mile down the road and my car died while stopping and would not restart untill the next morning!! got car running and when driving when accelarating once i gave it gas it boged out and died restarted a few times but did the same thing and then would not start for about an hour but can keep car running if spraying starting fluid right into manifold!!! car started idling high and low and has soon has you go she stalls and wont start for awhile!!! checked fuel system and am getting fuel to motor!! any help please!!!
Jul 18, 2010 at 2:19 PM
  • 75,988 POSTS
Start by checking the fuel pressure with a fuel pressure tester and get back with the readings we start here.
Jul 18, 2010 at 9:49 PM
FREDDY27
  • 5 POSTS
cant get the car started it starts but dies right away! hooked pressure tester and reading 40 and drops to 30 when i try to start it!!! changed tps yesterday and did not help! should i change the pressure regulator?
Jul 21, 2010 at 8:35 AM
  • 75,988 POSTS
Replace the FPR if it continues to drop like that could be an injector or the fuel pump check valve is leaking
Jul 21, 2010 at 10:08 AM
FREDDY27
  • 5 POSTS
got the car started and the pressure stayed at 35 when running and when the engine died it went right back to 40!! acorrding to repair book the FPR is good!! the manual said it should be between 40-47 not running and should drop 3-10 when running!!! should i try to clean the injectors
Jul 21, 2010 at 11:51 AM
  • 75,988 POSTS
This time disconnect the FPR vac hose plud it did it raise the pressure to 8-10psi?
Jul 21, 2010 at 12:46 PM
FREDDY27
  • 5 POSTS
first i would like to thank you for help!disconnected vac house and pluged pressure went up 9 psi. car will run till it gets to operating temp and then stalls like it ran out of fuel!!! what should i do next?
Jul 22, 2010 at 9:49 AM
FREDDY27
  • 5 POSTS
hello please help
Jul 28, 2010 at 4:08 AM
