1990 Chevy Celebrity car turns over but will not start
JOHNMAR
Engine Mechanical problem
1990 Chevy Celebrity 6 cyl Front Wheel Drive Automatic
I replaced the fuel pump and filter .... fuel filter.. checked fuel pressure .... changed the computer...its not getting anything to the noid lite .... what else can i check
Sep 18, 2008 at 5:53 AM
MMPRINCE4000
  • 8,548 POSTS
Check the fuses to the injectors, these are batch fire injectors, there should be 2 fuses both 5 amps.
Could also be the oil pressure switch, these have a backup system wherby if the FP relay goes bad, the oil pressure circuit will run the engine once oil pressure gets above 10psi.
Sep 23, 2008 at 12:59 AM
