1990 Chevy Celebrity 1990 celebrity wont start
63,000 MILES • 6 CYL • FWD • AUTOMATIC
YELLOWPAGES
Hi , i was in winter conditions i started the car it started fine .....i regret to say i didnt really let it warm up after starting it was 32 degrees ...got about 4 blocks and it stalled ...havent got it to start again yet .. but it cranks ..
Apr 28, 2010 at 4:28 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 28, 2010 at 6:51 AM
