1989 Chevy Celebrity Transmission
304,000 MILES • 4 CYL • 2WD • AUTOMATIC
MHARDNOYZ
I put the car in drive, 1, 2, or Reverse and something rattles in the engine compartment and it sounds like a peice of plastic rattling at a low rpm. I put the car on jack stands and put it in Drive and I can't find anything loose. It runs and drives great except for the fact that if I drive in the city, usually 35 mph, I have to put it into 2 or it rattles. And it rattles when I am stopped. I wanted to find out if this is a common problem with the early Hydra-Matic transmissions.
Dec 17, 2009 at 6:45 AM
HMAC300
  • 48,601 POSTS
it may be just eh heat sield for the catalytic converter is broken off and rattling. Have apro look at it they usually don't charge much for this type of stuff.
Feb 10, 2010 at 11:35 PM
