1989 Chevy Celebrity THE BRAKES IN MY CAR ARE NOT THE GOOD
200,000 MILES • 6 CYL • FWD • AUTOMATIC
ZOZOIFM
DEER SIR :
MY BRAKES ARENOT THAT GOOD EVEN I REPLASE THE DESKS WITH A VERYGOOD TYPE AND I REPLASE THE WASHERS OF THE WHOLE BRAKES SYSTEM AND I USE A VERY GOOD TYPE OF BRAKES LIQUID
Apr 6, 2010 at 9:59 PM
HMAC300
  • 48,601 POSTS
even if you replaced the disc pads doesn't mean you are going to have good brakes. As you havne' t really described your problem, you should take this to a pro as your master cylinder may be bad or have air in the system causing this. He'll be able to diagnose this correctly and fix what's wrong.
Apr 9, 2010 at 8:41 AM
