1989 Chevy Celebrity overheating
61,000 MILES • 6 CYL • FWD • AUTOMATIC
JPCHAIRES
Today, the water pump bypass gasket began to leak coolant quite badly. Coolant on ground and car starting to overheat on the gauge. I installed a new gasket and replaced the coolant. Now - I start the car and the temp gauge goes to the red. What is going on. Surely driving for less than 15 minutes with coolant leaking didn't damage the thermostat? What could be causing this?
May 9, 2009 at 1:36 PM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:2d829ab76d="JPChaires"]Engine Cooling problem
1989 Chevy Celebrity 6 cyl Front Wheel Drive Automatic 61000 miles
Today, the water pump bypass gasket began to leak coolant quite badly. Coolant on ground and car starting to overheat on the gauge. I installed a new gasket and replaced the coolant. Now - I start the car and the temp gauge goes to the red. What is going on. Surely driving for less than 15 minutes with coolant leaking didn't damage the thermostat? What could be causing this?[/quote:2d829ab76d]
Thank You for the Donation.
If you had to add quite a bit of coolant you may have an air bubble in the engine which will cause it to over heat quickly. What you can do it jack the vehicle up on the side of the car that has the highest access to bring the bubble to the top. Or you can run the vehicle at idle for a while with radiator cap loose or off.
Also when you replaced the gasket did you use a gasket sealer? If so you may have gotten some on the thermostat and it could be stuck closed.
May 9, 2009 at 2:25 PM
JPCHAIRES
I did use sealant with the gasket, but on this model, the thermostat is on the other side of the engine. Could small amounts of sealant travel that far and cause the thermostat to stick? Also - I see that this thermostat has an air release valve on top. Do I just loosen it and let the car run? Is this better than running with the cap off?
May 9, 2009 at 2:45 PM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:8dc20ad7d0="JPChaires"]I did use sealant with the gasket, but on this model, the thermostat is on the other side of the engine. Could small amounts of sealant travel that far and cause the thermostat to stick? Also - I see that this thermostat has an air release valve on top. Do I just loosen it and let the car run? Is this better than running with the cap off?[/quote:8dc20ad7d0]
Ok, No the sealer usually won't.
Since it does have the bleeder then yes you can use it however you will also most likely loose more coolant until the bubble finds its way out.
I don't know if it is better but will work either way.
May 9, 2009 at 2:59 PM
