1989 Chevy Celebrity No Spark
173,000 MILES • 4 CYL • FWD • AUTOMATIC
BROWNBOMBER
my 1989 chev. celebrity fails to start. I replaced the coils, wires, and plugs. The engine has good compression and the fuel pump is good. The fuses are good. I have tested the wires, and plugs individually and no spark at all.
Aug 25, 2009 at 11:38 AM
MIKESMECHANICAL
  • 6 POSTS
The most coomon cause of no spark on this model is a crank shaft position sensor failure, in order to test it you must remove it, it is attatched to the ignition module (where your coils are mounted) this is a complex job and if not performed properly the sensor can break and get stuck in the back of the engine block, if you are willing to take that chance let me know and I will send you detailed instructions on how to do it.
Sep 2, 2009 at 4:22 AM
