1989 Chevy Celebrity heard a pop under the dash
114,965 MILES • 6 CYL • 2WD • AUTOMATIC
WALTER32
I was driving down the road and heard a load pop from under the dash. I smelled nor saw smoke. Now my right side blinkers don't work. All of the lights come on and the four ways work, the right side just don't blink by themselves when turning right. My radio lost time at the same time it went from 1:30 to 10:30. I also started losing power. But after shutting it down and letting it sit for about 30 minutes it started back up and runs fine. blinker still just don't work. Is this something like the wiring harness or should I even worry about it.
Jul 28, 2008 at 7:41 AM
KLSHIEL
  • 163 POSTS
You need to get your blinkers working or you may get a ticket. The loud pop may have been a fuse. find your fuse box. Check all of the fuses, but you might start with the blinker fuses if thier labeled. Look over the wires and make sure nothing is burned. The part that causes the blinkers to blink is a small 2 inch box that should be under there it may have burned up internally.
Jul 28, 2008 at 8:05 AM
