1989 Chevy Celebrity fuel pump
THEGYVER
Engine Performance problem
1989 Chevy Celebrity 6 cyl Front Wheel Drive Automatic
Where is the fuel pump and also the fuel filter located on the 89 chevy celebrity eurosport 6cyl. I have the same surging as one of the other posts and need to go for smog check. I also get small backfires when surging and have been told most possible could be fuel filter or pump.
Jun 13, 2009 at 4:50 AM
  • 75,988 POSTS
The fuel filter is underneath your hood, behind the passenger side headlight, behind the core support and fuel pump is in the fuel tank.
Jun 13, 2009 at 8:13 AM
THEGYVER
Thank you....I would NEVER have looked by the headlight till I traced the rest of the fuel line under the car. You saved me a lot of time and trouble.
Jun 14, 2009 at 5:22 AM
