1989 Chevy Celebrity Celebrity 2.8 starts then stalls immed
145,000 MILES • 6 CYL • FWD • AUTOMATIC
PIPERMIKE
My 89 chevrolet celebrity with a 2.8 will start and run fine for anywhere from 2 - 30 seconds and then it will stall out like you shut it off. All the wires are good, the fuel pump runs and the filter is clean, the plugs are good and I just replaced the computer and it still does it. I cant figure out anywhere whats wrong with this.
Dec 20, 2008 at 3:15 AM
DOCFIXIT
  • 18,828 POSTS
ALDL connector on dash think right steering wheel jumper from treminal A to B key on check engine light will flash count flashes . ... 13 .. .... 24
It will flash pause flash again count flashes convert to number. Post
Dec 20, 2008 at 5:52 AM
