1989 Chevy Celebrity
130,000 MILES • 6 CYL • FWD • AUTOMATIC
TDOG1211
hello i have a 1989 chevy celebrity with the 2.8 and i just replaced the ignition control module about a week ago and it was running smooth but now it keeps dying after a short time on the road...could it be the computer?
Jan 8, 2009 at 3:17 PM
JDL
  • 16,098 POSTS
May I ask, did you do any testing before you replaced the icm? Why did you replace the icm?
Are there any codes? If your losing spark and injector pulse intermittently, the first thing I think about is the crank sensor. Without that signal, there is no spark or injector pulse. The crank sensor is about 20 bucks, the icm is about 100. I'm not telling you to replace anything, but, a problem with the rpm signal, I test the cheap part first.
Did you check for B+ and ground at the icm. You need to test, when the problem occurs. Yes, tracking down intermittent problems can be a pain.
Jan 10, 2009 at 7:41 AM
TDOG1211
when i brought the car into the shop they said the problem was the icm...so i replaced it and it worked for about a week but now the car wont stay running for more than a minute or so...any ideas? could it be the computer or something else?
Jan 10, 2009 at 11:08 AM
JDL
  • 16,098 POSTS
You could try to troubleshoot this yourself? Doing some of the basic tests and checking for codes is easy.
If you had the icm replaced recently, I'd call the shop and talk to them. A lot of shops will replace the coil pack-- plugs and wires-- along with the icm, encase one of the other issues caused the icm to go bad.
Jan 11, 2009 at 2:57 AM
TDOG1211
i dont have a code reader to do any futher testing....could the icm have been faulty?..only the icm was replaced and it worked for a little bit.
Jan 11, 2009 at 9:01 AM
JDL
  • 16,098 POSTS
Your obd1, you don't need a code reader. You can use a jumper wire between the A&B terminals at the data link connector, then turn on the key, no crank, just turn the key till the dash lites come on. The mil should start flashing, you count the flashes to get the codes.
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_2.jpg
Jan 12, 2009 at 1:07 AM
TDOG1211
as it turns out the fuel pump is going out..what a pain in the butt.you have been very helpful and i thank you for your time replying back to my problem..thanks again..keep up the good work.
Jan 13, 2009 at 7:32 AM
