1989 Chevy Celebrity
1989 CHEVROLET CELEBRITY
PILAR9247
Electrical problem
1989 Chevy Celebrity 179000 miles
My back lights stay on when I shut off the car. Any idea what is going on here?
Apr 9, 2009 at 11:01 AM
JDL
  • 16,098 POSTS
Hello, what lites are staying on?
If it is the brake lites, check the circuits at the brake switch. If it is the tail-lamps, check the circuits at the headlamp switch.
Apr 9, 2009 at 11:16 AM
PILAR9247
All I know is it is the 3 lights on each side of the car. Where would the brake switch and the headlamp switch be?
Apr 9, 2009 at 12:10 PM
JDL
  • 16,098 POSTS
The knob you pull to turn on the headlamps, that is the headlamp switch.
As far as the brake switch, follow the brake pedal arm,up, there should be a switch.
I'd check all wiring circuits before replacing anything.
Apr 9, 2009 at 12:54 PM
PILAR9247
Thanks. It was also suggested I check the ignition switch. Right now, I disconnect the battery when I am done driving and reconnect when I need to drive.
Apr 9, 2009 at 1:07 PM
