1988 Chevy Celebrity No pressure on brake peddle.
JIMMY R JACKSON
Brakes problem
1988 Chevy Celebrity 4 cyl Front Wheel Drive Automatic
Right rear wheel was grabbing on occasion. Thinking
poportionate valve, which is in the master cylinder, I replaced the master cylinder. Now I am unable to get the brake peddle to have pressure.
I did bench bleed the cylinder and each wheel but did not get a lot of pressure from the bleeders.
Jul 31, 2008 at 1:48 PM
MMPRINCE4000
  • 8,548 POSTS
You either have air in the system or a bad master cylinder.
I would re-bleed each wheel starting at the furthest one from the MC and working to closest.
If still no pedal then get a new MC under warranty. Make sure the MC rod to the brake pedal is installed properly. The loop usually faces up and if installed improperly can ruin the MC.
Sep 4, 2008 at 11:36 PM
