1988 Chevy Celebrity Master Cylinder
13,500 MILES • 6 CYL • 2WD • AUTOMATIC
SUZY09
How can you tell if the master cylinder needs replacing. I have had someone come over the last 2 weekends to bleed my brakes but it seems that air keeps getting in and the pedal goes to the floor just after he leaves, or when I drive again. Is this a master cylinder problem and it needs to be replaced? It's not leaking any fluid and he bled all four tires and the master cyl. yesteday.
Dec 14, 2009 at 4:19 AM
JDL
  • 16,098 POSTS
It sounds like the master cylinder has a problem.
Dec 14, 2009 at 4:43 AM
