1988 Chevy Celebrity charging system
CJBATKS
Electrical problem
1988 Chevy Celebrity 6 cyl Two Wheel Drive Automatic
Had Alt. checked and suppose to be good, so had battery checked. Put back together and sometimes it charges (weakly) and then quits and battery is dead
HELP
Nov 1, 2008 at 3:06 AM
MMPRINCE4000
  • 8,548 POSTS
Take the alt. off the car and have it bench tested again, try two different autoparts stores, Advance and Autozone for example. Have them spin it a minute or so before flipping the test switch and note exact volts it is putting out. If below 13.3, I would replace it.
Alt. should charge at least 13.3 or more when hot.
Nov 9, 2008 at 12:49 AM
