1988 Chevy Celebrity 88 Celebrity - no fuel or spark.
HANOVERFIST2009
Engine Performance problem
1988 Chevy Celebrity 4 cyl Front Wheel Drive Automatic
Replaced the injector and crankshaft position sensor. No fuel from injector or spark.
If it helps we've tried all the tricks in the guides here such as disconnecting all essential sensors and seeing if injector spray returns, etc.
Brother has years of experience in cars and we're both stumped and frustrated at this point. Any help would be appreciated - mom needs her car back. :)
Mar 5, 2010 at 11:38 AM
HMAC300
  • 48,601 POSTS
as far as fuel is concerned , chekc to see if you havepressure first you must have at leaaast 40p.s.i. to operate.ten go to te site here and click more repair services and then click on how to test iginition system. it goes through a step by step on how to do it. print it out and follow it. that should eliminate any problem you have..
Mar 19, 2010 at 5:57 AM
HANOVERFIST2009
Fixed!!
We ended up replacing the fuel injector, crank sensor, ecm, ignition module and rebuilding the throttle body.
Know what the problem was?? the parts store sold us a bad injector. First part in was our problem all along. :(
Mar 23, 2010 at 5:23 PM
