1987 Chevy Celebrity Won't accelerate
62,129 MILES • 4 CYL • FWD • AUTOMATIC
RCHITTY
Alright guys, so I have this celebrity. New engine dropped in about 60,000 miles ago. I just replaced the rod bearings and oil pump, and the engine for the most part cranks and runs fine. However, when you push on the gas, it hardly moves. Not like a clogged fuel filter, it's more like the transmission isn't delivering the power to the wheels.
-Engine RPM's spike (Car doesn't have a tach, so no idea what they're at exactly) and then dies down, all while holding the pedal constant
Could this be clutch slipping, something with the half shafts, or is the tranny finally dying on me? Thanks alot!
Oct 24, 2010 at 4:24 AM
  • 75,988 POSTS
Check the exhaust system for restriction, and test the throttle position and manifold absolute pressure sensors-if okay could be the tranny on its way out
Oct 24, 2010 at 5:26 AM
