1987 Chevy Celebrity Steering column
122,000 MILES • 6 CYL • FWD • AUTOMATIC
XBRYTEX
Hi, i bought this car used about 6 months ago and when i bought the steering wheel would wiggle up and down and also side to side. Today on my way to school rite when i got to the end of the road the steering locked up on me. I could not turn it at all so i went reverse all the way home.Also when i left for school the power would not go off and when i turned the steering whell sightly to the left the car would start without the key in it so i had to unhook the negitive on the battery. when i got home today the steering actual freed up a little and i put it in neutral and got it in the garage. i got a steering wheel puller and got the wheel off and know am trying to get the column off but am stuck. i cant figure out how to get the column off. Any ideas?
Thanks,
Clint
Feb 19, 2009 at 10:36 AM
JDL
  • 16,098 POSTS
Hello, hope you got it going your way? I'd probably take it loose from the rack/pinion, get the assembly out of the vehicle. You might be ahead to check the local salvage yards, see if you can find another assembly.
Feb 24, 2009 at 11:20 PM
