1987 Chevy Celebrity reprogram
52,987 MILES • 6 CYL • FWD • AUTOMATIC
GSTST4
I had to change a dead battery. I know by disconnecting the battery the computer probably eeds reprogramed. Can I do this and how?
Apr 24, 2010 at 9:41 AM
  • 75,988 POSTS
Computer relearning process-
Automatic Transmission
Set parking brake, start engine in "P" or "N" position. Warm-up vehicle to normal operating temperature or until cooling fan cycles.
Allow vehicle to idle for one minute in "N" position. Select "D" and allow engine to idle for one minute.
Accelerate at normal throttle position (20-50%) until vehicle shifts into top gear.
Cruise at light to medium throttle.
Decelerate to a stop, allowing vehicle to downshift, and use brakes normally.
Process may be repeated as necessary.
Apr 24, 2010 at 3:25 PM
GSTST4
The problem is the car will not start since disconnecting the battery and putting a new one in. It turns over, but no slight indication of starting.
Apr 25, 2010 at 5:19 AM
  • 75,988 POSTS
No cranking could mean starter, park and neutral switch and ignitiion switch-double check battery and connection
Apr 25, 2010 at 9:09 AM
