1987 Chevy Celebrity motor mounts
98,000 MILES • 6 CYL • FWD • AUTOMATIC
BENNYBOB420
how do i fully remove the motor mounts from this vehicle? i cant seem to remove a couple of the bolts holding the mounting bracket on... are there any reverse thread bolts on there??
Dec 21, 2009 at 7:14 AM
JDL
  • 16,098 POSTS
Welcome to the forum, can't remember all models. I use hoist to pick up on the motor just a little. Unscrew the nut off the motor mount bolt, first I unscrew the nut far enough to protect the threads on the end of bolt, then tap the end of bolt with hammer, see if I can get any movement. Even though the bolt may not be threaded all the way, sometimes it helps to unscrew the bolt. Don't remember any reverse threads.
The autozone site probably has free info on the motor mount removal. I have to log off, somebody knocking on the door. goodluck
Dec 21, 2009 at 8:30 AM
