1987 Chevy Celebrity fuel leak
180,000 MILES • 4 CYL • FWD • AUTOMATIC
LARRYWC
This car appears to have a throttle body fuel injector. Is that correct? Anyway, the engine is not turning over and it's leaking from the throttle body fuel injector. When I pulled a spark plug I could see that it was getting spark. When I pulled the air cleaner off I could see that it was getting gas but leaking on the outside fo the fuel injector. Do I have to replace the whole thing or can it be repared?
Dec 12, 2008 at 4:51 AM
  • 75,988 POSTS
It can be repaired-remove the injector and investigate
Dec 12, 2008 at 5:00 AM
