1987 Chevy Celebrity code 45
1987 CHEVROLET CELEBRITY
CHRIS ALLEN BAKER
Engine Performance problem
1987 Chevy Celebrity 4 cyl Front Wheel Drive Automatic
getting code 45,rich exaust, after idling a few minutes runs a little rough especialy when cold,replaced oxy sensor,injector and fuel press regulator.
Oct 18, 2009 at 8:50 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you what is your engine size in liter and the 8th digit of your VIN.
Oct 18, 2009 at 10:50 AM
CHRIS ALLEN BAKER
its the 2.5...8th digit is R
Oct 18, 2009 at 11:11 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info……..
For running rich it may be your manifold air temp sensor, coolant temp sensor, or oxygen sensor which you say you changed. For rough idle it could be any number of things but possible throttle position sensor or mass air flow sensor.
Now it could also be plug wires, plugs etc……..when was the last tune up?
If we have information in the manual for checking the above sensors would you like it?
Oct 18, 2009 at 1:49 PM
IMPALASS
  • 3,112 POSTS
Hello –
Also how many miles are on the vehicle……..was it idling rough after the change of the 02 change or before.
Have you checked all your vacuum hoses for cracks, loose connections etc……a vacuum leak will also cause a rough idle
Oct 18, 2009 at 2:06 PM
CARLIFE65
  • 200 POSTS
you have two oxygen sensor, you need to replace both of them
Oct 25, 2009 at 6:45 PM
CHRIS ALLEN BAKER
My car is running fine now, I replace the egr valve with the old one, the one I returned near positive it was the wrong one I have a guy look at the parts store if I had more than one oxygen sensor I only have the one. The having that code 45 every once in awhile is the least of my problems now that I got it running the way it used to I read somewhere that it could be my charcoal canister I don't know if they plug up or what hope all is well thanks for your time
Oct 26, 2009 at 12:59 PM
