My car is idling really high, what is the problem?
Thursday, November 4th, 2010 AT 2:13 PM
JDL
MECHANIC
If this is a speed density system, map only, unmetered air can cause the idle to go high. Any applicable mil codes? You can clean the throttle-body, check the iac, check throttle valve/linkage.
