1986 Chevy Celebrity wont turn over
109,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERICHENRY48
i had a a leak in my lifter cam and replaced the gasket. i went down and power washed the engine and doing so i got water in the distributer. so i cleaned the distributor and rotor and replaced the coil .now it tries to start but wont catch
Jul 28, 2010 at 3:05 PM
  • 75,988 POSTS
now it tries to start but wont catch -Its cranking over and will not start-
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 28, 2010 at 4:59 PM
