1986 Chevy Celebrity water pump and serpinten belt
HUNTERCMK
Engine Cooling problem
1986 Chevy Celebrity 6 cyl Front Wheel Drive Automatic
I have never put a water pump on before I can take it off but my problem is how to put the belt back on this model takes a serpinten belt and there is an airconditioner.I a do not know the correct procedure tho replace it . will I need to loosen any thing? thanks
Oct 28, 2009 at 10:18 AM
  • 110,248 POSTS
The belt is on with the automatic tensionier. You just release the tension from it and remove the belt. If you need a belt diagram, go to the belt routing diagrams site on this page.
Nov 3, 2009 at 1:39 AM
