1986 Chevy Celebrity turns over but will not start
RRRICKD
Electrical problem
1986 Chevy Celebrity 6 cyl Front Wheel Drive Automatic
I drove my car which started fine to a friends to do some work for her and when i got done , got back to the car I tried to start it and all it would do is turn over..pushed it home.. checked all the fuses, 1 was bad replaced it checked to see if it was getting spark. it was. still just turning over any idea on what i can check out next. and where and how would i go about checking - is their a seperate fuel pump fuse thats different than the fuse box under the dash? any fusable links?
Jul 19, 2008 at 5:57 AM
  • 75,988 POSTS
Check fuse no.2 and also check the fuel pressure and injector/s pulses
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_fuse_1.jpg
Jul 19, 2008 at 8:03 AM
RRRICKD
thanks rasmataz for your anwser...I will recheck the #2 fuse... do you know how I would go about checking the fuel pressure and the injector pulses.. Is this something I need special tools for ??..
Jul 19, 2008 at 10:29 AM
  • 75,988 POSTS
You need a fuel pressure gauge designed for your fuel system and also a noid lite to check for injection pulses-
Jul 20, 2008 at 9:00 PM
