1986 Chevy Celebrity MAP sensor...WHERE IS IT???
99,000 MILES • 6 CYL • FWD • AUTOMATIC
CELEBRITY86
i have searched everywhere and looked all over the internet but i cannot seem to find the darn manifold absolute pressure sensor to replace. i have the v6 2.8 MPFI. i even bought the part to make sure i knew what it looked like. i have the haynes manual and it does no good. will someone please help me?!??!
Apr 17, 2008 at 3:21 PM
  • 75,988 POSTS
If its a carb system it has it-yours is an MPFI it has a mass airflow sensor its in the air intake duct-
Apr 17, 2008 at 3:31 PM
CELEBRITY86
not according to the haynes manual. it says that the 2.8 and 3.1 MPFI v6 have it, there is a picture of the engine compartment and numbers on it that relate to each part. the map number is just general and i looked all over where it says it is.
Apr 17, 2008 at 3:34 PM
  • 75,988 POSTS
I've reviewed the MAP sensor on Mitchell1 ondemand5.com it says you don't have it if you have a 2.8 MPFI- engine.
Good Luck
Apr 17, 2008 at 4:43 PM
CELEBRITY86
then maybe you can help me. my engine light is on and the code given to me is number 34. this means either the mass airflow sensor has low air flow or it is the manifold absolute pressure sensor signal voltage low. i replaced the mass airflow sensor and the code still comes up. i even took the air filter out to improve airflow.
Apr 17, 2008 at 5:20 PM
