1986 Chevy Celebrity knocking rod
94,000 MILES • 4 CYL • 2WD • AUTOMATIC
JLR1970
need to know whta it takes to fix knocking rod
Sep 25, 2009 at 2:22 AM
HMAC300
  • 48,601 POSTS
if the rod bearing hasn't spun in the rod then you can just get what they call a crank kit at a good auto parts store. You will have to pull the engine to put this in right. You can pull the pan in the car and find out if the rodbearing has spun. Look for the rod that moves the most on the crankshaft.
Oct 13, 2009 at 6:00 AM
