1986 Chevy Celebrity
WESLEY33
1986 Chevy Celebrity 4 cyl Front Wheel Drive Automatic
I just recently bought this car, I have replaced the fuel fiter, the spark plugs, and put fresh gas in it, I have broken down the pressure regulator and pulled the injector, cleaned everything and reassymbeled it. It would not start until finally I primed it by pouring a little gas in the carb, it ran fne until I jacked it up while it was running then it started chugging real bad, when I would tr to give it gas it would die,. I have thought of everything so any suggestion would be greatly appeciated.
Sep 9, 2010 at 10:00 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs-could be the fuel pump
Sep 10, 2010 at 1:55 AM
