Tons Of Vibration---NEED HELP
CHEVYGIRL07
  • CHEVROLET CAVALIER
Chevy Cavalier, 1997, 90,000, 2.2L, I am having a lot of vibration in the front of the car. We have changed out drive axle in passenger side, changed Top motor mount (which was broken), changed tires, and still has vibration in right front. Makes a clunking noise when pulled into gear. Any suggestions on what might be the problem? Thanks
Sunday, March 18th, 2007 AT 8:35 AM
WARNER3885
  • 7 POSTS
When you rejplaced the tires did you have them balanced? And for the clunking check all the mounts even the tranny mount, also should check the other axle. Hope this helps :wink:
Tuesday, March 20th, 2007 AT 10:00 AM
