1985 Chevrolet Cavalier Severe Oil Leak
JESSE79
85 Chevy cavalier 120000 milies, 4 cylinder. My father in law bought the car cheap. It goes through oil insanely fast, we've checked the oil filter and the oil pan gasket, but they dont appear to be the problem. When you pour the oil in and duck under for a look, you can actually see the fresh oil pouring directly on the pavement. Not all, but most. Any suggestions would be helpful.
Aug 3, 2007 at 7:28 PM
  • 75,988 POSTS
[quote:36c6462a71="Jesse79"]85 Chevy cavalier 120000 milies, 4 cylinder. My father in law bought the car cheap. It goes through oil insanely fast, we've checked the oil filter and the oil pan gasket, but they dont appear to be the problem. When you pour the oil in and duck under for a look, you can actually see the fresh oil pouring directly on the pavement. Not all, but most. Any suggestions would be helpful.[/quote:36c6462a71]
You need to locate where the leak is coming from.
Couild be coming from the oil pressure sending unit and valve cover
Aug 3, 2007 at 10:48 PM
Suggested Repair
Locate the exact leak source. Check the oil pressure sending unit and the valve cover, since either can dump fresh oil onto the pavement.
Conversation Summary
The owner of a 1985 Chevrolet Cavalier with a 4-cylinder engine and about 120,000 miles reports rapid oil loss. The oil filter and oil pan gasket were checked and did not appear to be leaking, but fresh oil can be seen pouring onto the pavement after oil is added. The expert advised locating the leak and suggested the oil pressure sending unit or valve cover as possible sources.
