1998 Chevrolet Cavalier Rough Misfire Fix
BELKER
  • 6 POSTS
1998 cavalier-2.2 standard-218k kilometers.
have new plus, new plug wires. code reads muliple
random cylinder misfires. will be running good then suddenly starts missing and sometimes you have to keep it reved up to keep it running. also noticed it does not start as well as it did . i suspect map sensor?
Code was showing up before changing wires and plugs.coil packs or injectors have not been changed, i did check injectors for leaks, couldn't see any.
Feb 26, 2007 at 3:35 AM
CHEVY22
  • 1,375 POSTS
did the code show up before of after the plugs and wires???
Feb 26, 2007 at 8:06 AM
GMFACE
  • 23 POSTS
Have any of your coil packs or injectors been changed recently?
Feb 26, 2007 at 3:53 PM
GMFACE
  • 23 POSTS
Sorry, that was a stupid question on my part.
I would suggest having your injectors checked again. It may be they aren't atomizing the fuel properly once the engine has warmed.
Mar 1, 2007 at 10:44 AM
BELKER
  • 6 POSTS
[quote:ffb5343be5="belker"]1998 cavalier-2.2 standard-218k kilometers.
Code was showing up before changing wires and plugs.coil packs or injectors have not been changed, i did check injectors for leaks, couldn't see any.[/quote:ffb5343be5]It finally registered a code. egr was acting up. Cleaned carbon out working good now. Thanx everyone for your help.
Mar 15, 2007 at 11:56 AM
Suggested Repair
Clean carbon buildup from the EGR valve and passages. The owner reported that an EGR code appeared and cleaning the carbon restored normal running.
Conversation Summary
A 1998 Chevrolet Cavalier 2.2 with about 218,000 km ran well, then suddenly misfired and sometimes needed higher RPM to stay running. Starting had also worsened. Random multiple-cylinder misfire codes were present before new plugs and wires were installed. Coil packs and injectors had not been replaced, and a leak check of the injectors showed nothing. A MAP sensor was suspected, and an injector atomization problem was also suggested. The owner later reported an EGR code; cleaning carbon from the EGR resolved the problem.
