motor stop when put in gear
PEPEL081
  • 6 POSTS
Hi !
I have a 1997 Chevrolet Cavalier 2,2l automatic transmission with 160,000 km...Motor starts and runs good .Go for a ride for 15 about minutes then it stalls.
When this appens i parked it along the road.The motor starts good and runs good on park or neutral but as soon i put the tranny in drive,reverse,L1,or L2 position the tranny have a hard knocking sound on the wheel shaft and the motor stalls ,if i let it stay for about 30 minutes i can start and go continue driving but the problem comes back
Jun 24, 2007 at 3:21 PM
E40WATER12
  • 522 POSTS
Sounds to me youre transmission lockup switch is acting up, Are u getting any check engine light displayed?.
Jun 25, 2007 at 7:33 AM
PEPEL081
  • 6 POSTS
Have changed the speed sensor but still the same problem...where is the transmission lockup swtch..
Could it be the tork converter pressure not working
Jun 25, 2007 at 8:52 AM
E40WATER12
  • 522 POSTS
It should be located near the front of the transmission, U should see a black or gray plastic electrical plug,
Jun 25, 2007 at 7:17 PM
PEPEL081
  • 6 POSTS
Found my trouble...
Transmission lockup switch or otherwise called
the tork converter control switch witch is placed right in front right sidewhen in front of tranny ...
Have unplugged it and ar runs great..
Jun 27, 2007 at 1:12 PM
