1991 Chevy Cavalier Reverse Won't Engage
STEVEN JONES
1991 Chevy cavilier 159000 miles. The transmission will shift into reverse sometimes and other times it will not. The shifter will not even try to go into reverse it feels like something is blocking it. The transmission is manual. Steve
May 28, 2006 at 5:54 AM
BURRBRIAN
  • 158 POSTS
Have you tried to put it in another gear before shifting into reverse? Hit 2nd or 3rd before you try reverse and see if this lets you into reverse. Also does it grind any when you try to go into reverse? It sounds like you have synchronizer problems but don't take my word for gospel. I would also check my adjustment and make sure it is disengaging completely. If everything checks out OK I would have a good tranny mech. check it out Hope this gives you something to work with. Good luck 8)
Jun 1, 2006 at 12:08 AM
Suggested Repair
Before selecting reverse, shift into 2nd or 3rd and note any grinding. Check shifter adjustment and confirm the clutch fully disengages. If those checks do not restore reverse, have a transmission mechanic inspect it, possibly for synchronizer issues.
Conversation Summary
A 1991 Chevrolet Cavalier with a manual transmission and about 159,000 miles sometimes will not go into reverse, and the shifter feels blocked. The expert suggested selecting 2nd or 3rd first, checking for grinding, verifying adjustment and full clutch disengagement, and having a transmission mechanic inspect it if those checks are fine. Synchronizer trouble was mentioned only as a possibility.
