Leaking Coolant
WAVERIDR007
I have recently been leaking large amounts of coolant from my 1993 z24 chevy cavalier (v6 3.1). When i am standing at the front of the car the leak is towards the back. I was wondering where the coolant is leaking from.Any assistance much appreciated!!
Jun 14, 2007 at 6:11 AM
MIKE H R
  • 3,094 POSTS
Check the hoses going into the firewall that connect to the heater core.
Jun 14, 2007 at 9:16 AM
WILLDAVIS
I was having the same problem with my 97 cav and it turned out that the water pump had several hair line cracks in it. I would recommend checking the water pump.
Jun 27, 2007 at 9:34 PM
MIKE H R
  • 3,094 POSTS
Have the system pressure checked. that way you can tell exactly where you are loosing fluid.
Jun 28, 2007 at 1:04 AM
