2003 Chevy Cavalier Dome Light Alarm
NININANER
I have a 2 wheel drive, automatic 2003 Chevy Cavalier (96400 mi.) that seems to have a problem.......first when i get in my car and close the door and put on my seat belt, the overhead light is supposed to turn off but lately it does not, until pull out of whereever i am and put the car in drive......it will also come on periodically esp at stoplights.......THEN whenever i park the car the alarm will sound off by itself after about 5-10 min after it having been parked.......what in the world is going on here??
Jun 15, 2007 at 1:43 AM
E40WATER12
  • 522 POSTS
Sounds to me you could have a problem with those plastic door switches on youre car, The contacts get corrioded in which causes the car to function improper. Try the passanger side door see if it makes a difference.
Jun 16, 2007 at 9:27 PM
Suggested Repair
Inspect the plastic door switches for corroded contacts, which can make the interior light and alarm behave incorrectly. Compare operation with the passenger-side door to see whether that switch is the cause.
Conversation Summary
A 2003 Chevy Cavalier owner reports the overhead light staying on after the door is closed and the seat belt fastened until the car is shifted into drive, coming on at stoplights, and the alarm sounding 5-10 minutes after parking. The expert suggests corroded plastic door-switch contacts and recommends checking whether the passenger-side door makes a difference.
