Chevrolet Cavalier Blower Speeds Fail
SJANT71
OK first off I'm not a mechanic and I don't know how to check to see how many volts are running to things. heres my problem: when I run my ac or heater the 1st two levels don't work the second two do. it gets cold it gets hot no other problems. (other than rear defrost doesn't work) level 3 is starting to sound kind of ragged. is this the blower motor? just want some kind of idea so I don't get blindsided at the mechanics.
Apr 4, 2007 at 11:25 AM
  • 75,988 POSTS
[quote:c4921696bd="sjant71"]OK first off I'm not a mechanic and I don't know how to check to see how many volts are running to things. heres my problem: when I run my ac or heater the 1st two levels don't work the second two do. it gets cold it gets hot no other problems. (other than rear defrost doesn't work) level 3 is starting to sound kind of ragged. is this the blower motor? just want some kind of idea so I don't get blindsided at the mechanics.[/quote:c4921696bd]
Sounds like the resistor pack-dunno the location
Apr 5, 2007 at 10:13 AM
Suggested Repair
Have the blower motor resistor pack checked and replaced if faulty. The expert did not know its location on this Cavalier.
Conversation Summary
The owner of a Chevrolet Cavalier reports that the first two heater and A/C blower speeds do not work, while the higher speeds do. Heating and cooling still function, the rear defrost does not work, and speed 3 is starting to sound ragged. The owner asked whether the blower motor is at fault. The expert said the symptoms sound like a failed resistor pack but did not know its location.
