Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Engine
Cylinder Head
Torque
Head bolt torque specs needed?
1988 CHEVROLET CAVALIER
153,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
MEMBER
I am replacing head gasket and need head bolt torque specs.
Nov 4, 2024 at 1:54 PM
Experienced Mechanic
I only found the cylinder head torque specs for a 2.0-liter engine, can you please double check the engine size?
the head bolt torque specifications are as follows:
Cylinder Head
Long 73-83 ft.lb
Short 62-70 ft.lb
Let us know if you need anything else.
Nov 5, 2024 at 3:47 AM
TJMOWBRAY
MEMBER
Sorry, yes, it is a 2.0 liter.
Nov 5, 2024 at 8:15 AM
TJMOWBRAY
MEMBER
Also need crank bolt torque specs and valve cover.
Nov 5, 2024 at 8:16 AM
Okay good, sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Nov 6, 2024 at 1:27 AM
TJMOWBRAY
MEMBER
Okay, thanks.
Nov 6, 2024 at 9:00 AM
TJMOWBRAY
MEMBER
With two different torque specs how should I tighten the head bolts in increments? And if so what increments?
Dec 1, 2024 at 4:49 AM (Merged)
Cylinder Head
Long 73-83 ft. Lb
Short 62-70 ft. Lb
I would split the tightening into three parts.
Apr 29, 2025 at 5:06 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
