Head bolt torque specs needed?
153,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 85 POSTS
I am replacing head gasket and need head bolt torque specs.
Nov 4, 2024 at 1:54 PM
  • 55,658 POSTS
I only found the cylinder head torque specs for a 2.0-liter engine, can you please double check the engine size?
the head bolt torque specifications are as follows:
Cylinder Head
Long 73-83 ft.lb
Short 62-70 ft.lb
Let us know if you need anything else.
Nov 5, 2024 at 3:47 AM
TJMOWBRAY
  • 85 POSTS
Sorry, yes, it is a 2.0 liter.
Nov 5, 2024 at 8:15 AM
TJMOWBRAY
  • 85 POSTS
Also need crank bolt torque specs and valve cover.
Nov 5, 2024 at 8:16 AM
  • 55,658 POSTS
Okay good, sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Nov 6, 2024 at 1:27 AM
TJMOWBRAY
  • 85 POSTS
Okay, thanks.
Nov 6, 2024 at 9:00 AM
TJMOWBRAY
  • 85 POSTS
With two different torque specs how should I tighten the head bolts in increments? And if so what increments?
Dec 1, 2024 at 4:49 AM (Merged)
  • 55,658 POSTS
Cylinder Head
Long 73-83 ft. Lb
Short 62-70 ft. Lb
I would split the tightening into three parts.
Apr 29, 2025 at 5:06 AM
