1997 Chevy Cavalier CKP Sensor Mismatch Fix
I hope you were able to figure out the secret so I can get this thing running.
Thanks
Suggested Repair
Use the crankshaft position sensor that matches the vehicle's original computer and wiring—the two-wire sensor for the 1997 Cavalier—not the donor engine's three-wire sensor. Confirm the sensor length is correct and that required sensors, including the camshaft sensor, are present. Match electronics to the car and hard parts to the engine.
Conversation Summary
A 1997 Chevrolet Cavalier 2.2 owner installed a 1996 2.2 engine and found the crankshaft position sensor connectors did not match: the car used a two-wire sensor while the donor engine used a three-wire sensor. An expert posted wiring information but was unsure about splicing. Another contributor advised matching electronics to the original car and hard parts to the engine, and using a sensor of the correct length. A later owner with the same mismatch installed the correct two-wire sensor and reported the car then ran normally.
