Cooling fan wont come on.
DSEAEJBJ
I have just replaced the head cylinder,head gaskets, relay ans cooling sensor, however the fan still is not coming on and it is causing the car to get hot. What could be the problem?
Jul 11, 2007 at 1:52 PM
E40WATER12
  • 522 POSTS
Have you tested to see if your cooling fan is working? Also, I would check the cooling fan fuse. You could have a worn out fan relay switch.
Oct 3, 2017 at 2:46 PM
DSEAEJBJ
The fan still will not come on even after changing the relays and the sensor. Is there something else that I am missing that could be keeping the fan from running while the sensor is plugged in?
SNWOODS72
I have the same problem with my 2005 Cavalier. I am taking it to the dealership. I know they will charge a fortune, but I have no other choice. I will let you know what they say. I have also changed everything I can think of.
