1996 Chevy Cavalier Knock After Head Swap
JLEE1192
I have a 1996 Chevy Cavalier, it has 36000 miles, with a 2.2 engine. The car overheated and warped the head, I replaced the head with a used one, mileage unknown. I am getting good oil pressure but the engine is knocking, very bad it quiets some after warming up.could this be a bad rocker arm and valve, or possibly a collapsed lifter. any help with this will be greatly appreciated! I am about to get the origanal head machined and pressure checked then doing another swap, how would I check the lifters to make sure they are o.k. ? Thanks again for your time and comments
Nov 8, 2007 at 3:18 AM
MERLIN2021
  • 17,250 POSTS
With the valve cover removed, check for play, up and down motion while engine is off, if the pushrod moves excessivly, lifter is collapsed, or push rod is bent. Usually load rapping is from the lower end, mains and rods!
Nov 9, 2007 at 7:00 AM
JLEE1192
thanks for the reply , and advice on the lifters. I have found that there is no play in the push rods. just for s#*%s and giggles , with the vavle cover off I poured fresh oil on each rocker arm then started the engine. I heard no knocking for about 5-6 mins then it slowly returned. is this an indication of something, maybe Iam not getting the oil pressure I thought I was? Or maybe bad rocker and valve. I can see oil pumped through each of the rods on to each arm.
Nov 10, 2007 at 7:55 AM
MERLIN2021
  • 17,250 POSTS
Are we talking tapping or engine knock? Use a real oil pressure gauge, unscrew you oil sender and screw in the tester, get the readings, and then get back to me! If oil pressure is low the first place you'll hear it is the lifters...
Nov 10, 2007 at 8:38 AM
Suggested Repair
With the valve cover off and the engine stopped, check the pushrods for excessive up-and-down play, which can indicate a collapsed lifter or bent pushrod. Determine whether the noise is valvetrain tapping or a lower-end knock. Replace the oil sender with a mechanical gauge and verify actual oil pressure, since low pressure often appears first at the lifters.
Conversation Summary
The owner of a 1996 Chevrolet Cavalier 2.2 replaced a warped head after overheating and now hears a loud knock that quiets somewhat when warm, despite reportedly good oil pressure. The expert advised checking pushrod play with the cover removed. The owner found no play, saw oil reaching the rockers, and said the noise returned after several minutes. The expert then recommended distinguishing a tap from a knock and measuring oil pressure with a mechanical gauge.
