1996 Chevy Cavalier Knock After Head Swap
Suggested Repair
With the valve cover off and the engine stopped, check the pushrods for excessive up-and-down play, which can indicate a collapsed lifter or bent pushrod. Determine whether the noise is valvetrain tapping or a lower-end knock. Replace the oil sender with a mechanical gauge and verify actual oil pressure, since low pressure often appears first at the lifters.
Conversation Summary
The owner of a 1996 Chevrolet Cavalier 2.2 replaced a warped head after overheating and now hears a loud knock that quiets somewhat when warm, despite reportedly good oil pressure. The expert advised checking pushrod play with the cover removed. The owner found no play, saw oil reaching the rockers, and said the noise returned after several minutes. The expert then recommended distinguishing a tap from a knock and measuring oil pressure with a mechanical gauge.
