1998 Chevrolet Cavalier Low Idle
HORNET
Have a 1998 Chevy Caviler that came in for no idle, found bad plugs and wires. Installed new plugs and wires. The car now idles at around 560RPM when hot. No codes are present. Any ideas what the problem is. The Air Idle motor costs $103 and would rather not replace it unless I new for sure its the problem.
Jun 1, 2006 at 12:31 PM
JDL
  • 16,098 POSTS
Sorry for the late reply.
If your saying the idle is too low. I'd clean the throttle body and iac and see if it helps. Use a scanner, look at live engine data for iac counts. 0 counts- the iac is fully extended, 255 counts the iac pentle is fully retracted. Normal at idle-4--60 counts.
If idle is 100 rpms less than required for 19 seconds, a code should set, p0506. You can use the scanner to check idle and idle required, see if any difference? Even if the code doesn't set, you could still run the diagnostics for the code.
I realize this is an old post. They are improving the site all the tijme, more moderators and it's free. Keep us in mind.
Have a good day.
Mar 22, 2015 at 4:17 AM
Suggested Repair
Clean the throttle body and idle air control valve, then scan live data for IAC counts (about 40-60 at idle). Compare actual idle with required idle and run P0506 diagnostics even if no code is set.
Conversation Summary
A 1998 Chevrolet Cavalier came in with no idle. Bad plugs and wires were replaced, but the engine still idles around 560 RPM when hot with no codes. The expert recommended cleaning the throttle body and IAC, checking IAC counts, comparing actual and required idle, and running P0506 diagnostics if the idle remains too low.
