2001 Chevrolet Cavalier Shuts Off
GMYHS
I have a 2001 Caviler with 85k was running fine then yesterday going 65mph it shuts off, and wont start again, my neighbor thinks it might have to do with the timing but it doesn't have a timing belt or chain. If the motor has to be pulled how much would that cost?
Jun 11, 2007 at 4:49 AM
E40WATER12
  • 522 POSTS
Do u have a check engine light on? If so I would get the codes scanned. Then repair the sensors that are broken, Also if you got not trouble codes, I would get a fuel pressure test done, Also get youre fuel pressure regulator tested.
Jun 12, 2007 at 9:19 PM
Suggested Repair
Scan for trouble codes and repair any failed sensors. If there are no codes, test fuel pressure and the fuel pressure regulator.
Conversation Summary
The owner of a 2001 Chevrolet Cavalier said it shut off while traveling at 65 mph and would not restart. A neighbor suspected a timing problem, although the owner said it has no timing belt or chain and asked about the cost of removing the engine. The expert recommended checking for a check engine light, scanning codes, repairing failed sensors, and testing fuel pressure and the fuel pressure regulator if no codes are present.
