Cavalier won't start antitheft light is on
CPARKER415
I have a 98 chev cavalier and it won't start. Replaced the fuel pump and it still won't start. Antitheft light is on.
Apr 15, 2006 at 8:35 AM
LOSONE
  • 1,616 POSTS
Will the engine turn over? What engine and how many miles? Doe the key have a computer chip Let me know
Apr 15, 2006 at 10:59 AM
PUDDIINN
I'm not a moderator but I had the same problem with my 97 trans am. the security light was on for a while then one day I turned the key and nothing. Not even a click. It was a wire in the ignition switch, shut down the VTD system. Just a thought. good luck.
Apr 17, 2006 at 4:05 AM
WISEGUY_75
  • 7 POSTS
if you leave the key to the "run" position for 10-15 mins this should shut off the security light and then maybe yo will be able to start the car...
good luck
Apr 25, 2006 at 2:24 AM
