I have a 98 chev cavalier and it won't start. Replaced the fuel pump and it still won't start. Antitheft light is on.
Saturday, April 15th, 2006 AT 3:35 PM
LOSONE
MECHANIC
Will the engine turn over? What engine and how many miles? Doe the key have a computer chip Let me know
SPONSORED LINKS
Saturday, April 15th, 2006 AT 5:59 PM
PUDDIINN
MEMBER
I'm not a moderator but I had the same problem with my 97 trans am. The security light was on for a while then one day I turned the key and nothing. Not even a click. It was a wire in the ignition switch, shut down the VTD system. Just a thought. Good luck.
Monday, April 17th, 2006 AT 11:05 AM
WISEGUY_75
MEMBER
If you leave the key to the "run" position for 10-15 mins this should shut off the security light and then maybe yo will be able to start the car.
