Cavalier ABS light on
TAZ82773
I have a 92 chevrolet cavalier.The ABS light is on after I changed the rotors and brake pads.It wasn't on before. Is there something I did when fixing the brakes?
Apr 23, 2006 at 2:26 PM
CAVALIER
  • 16 POSTS
92 Cavaliers are prone to ABS problems.
Make sure you didn't crimp or twist any of the wires running to the ABS assembly. Also make sure you didn't accidently pull or loosen the plug from the ABS housing.
Apr 25, 2006 at 5:41 AM
