car dies when put into gear
DLANG51
chevy cavlair 1991 172987 miles 2.2 4 cyc eng car runs good but when you put it in gear it dies is not timing because if does not do it all the time is there a sensor that could cause this problem :?: :idea:
Nov 1, 2007 at 3:19 PM
BERNICELIA
Hello
just had same problem. Car still runs, just stop when put in gear, then when i let it sit an had car shut off a minute, it started up again.
Selinoid switch, inside tranny, just remove cover an it snps out an new one snaps right back in.
135.00 total, but that was to high could get for less.
Good luck
happy holidays
bernice-lia
Dec 20, 2007 at 3:07 AM
